Where is the headlight horizontal adjuster?
Old Nov 19, 2011 | 01:42 PM
buddy7's Avatar
Default Where is the headlight horizontal adjuster?
I needed to adjust a new passenger side headlight housing. I found one adjuster, a T20 Torx screwdriver goes in vertically, it's to the rear of the housing and lines up with the right side of the A/C thingy. I turned it and it is the vertical adjuster. Fortunately that is the one that most needed adjustment.
But I could not find the horizontal adjuster anywhere. Could someone post a photo of it?
Thanks,
Buddy
Old Nov 20, 2011 | 07:28 PM
You are much more likely to get a helpful response if you let people know what kind of car you are asking about. Model (coupe or convertible/sedan) and year are essential when asking about a Sebring.
Old Nov 20, 2011 | 08:51 PM
buddy7's Avatar
As it says in the posting, it is a 2004 Sebring Touring, which is the sedan.
Old Nov 21, 2011 | 09:56 AM
You meant "As it should have said..."
Anyway, there's a hole in the radiator support crossmember directly in front of the power steering reservoir. Look down in that hole. It should be there.
nelgin
Sep 12, 2011 07:54 PM
SSzretter
Aug 19, 2010 04:41 AM
loud300m
Aug 24, 2009 01:25 PM
Elvis
Jan 15, 2006 06:44 AM
bazzwell
Oct 4, 2005 04:15 AM
