Will NOT start :(
Old Feb 20, 2012 | 09:29 AM
MrNoizyToyz's Avatar
Default Will NOT start :(
I have a 2000 Sebring convertible 2.5,I changed the spark plugs and did the valve cover gaskets put everything back as it was and now it will not start,it started before I did the work to it,I checked to see if I had spark,no spark,Is it possible the Distributor can go bad ? the plugs that go to it have power
Old Feb 20, 2012 | 03:29 PM
The distributor on that engine is almost always the culprit. Might want to check for codes before you shell out the bux.
Old Feb 21, 2012 | 07:18 AM
Default Wont start
Well my Distributor Assembly will be here today,I will find out today if that's the culprit
Old Feb 21, 2012 | 12:38 PM
I put in the Distributor no luck
Old Feb 21, 2012 | 02:08 PM
What did you get when you checked for codes?
Old Feb 21, 2012 | 03:41 PM
I have to wait for a buddy of mine to bring the diagnostic tool to get the codes
Old Feb 21, 2012 | 09:00 PM
Ok,this is what I got from code reading,
Troubleshooting P0601
Definition
aaECM internal fault
Explanation
aaECM unable to communicate on SPI line
Probable cause
aa1.-Shorted input sensor
aa2.-Shorted electrical circuit
aa3.-Failed ECM
Troubleshooting P0420
Definition
aaCatalyst efficiency low-bank 1
Explanation
The oxygen sensors monitor the Catalytic Converters
ability to store oxygen.
Probable cause
1.Catalytic converter defective (failure
possibly due to #2,3,or 4)
2.Engine misfire or running condition
3.larg vacuum leak
4.engine oil leakage into exhaust-valve guide
I checked for vacuum leaks but most of it has nothing to do with spark,the car ran fine before I decided to change the plugs and fix the oil leaking into spark-plug holes,the ECM
sounds Scary
Old Feb 21, 2012 | 10:34 PM
ECM replacement is not that bad but it's not cheap. Search on line. For about $200, you send them your VIN and mileage and they send you a rebuilt computer that pretty much plugs in. I did it for my 2001 when I got the dreaded 601 code and the problem was gone.
Replacement of the catalytic converter is much worse.
Old Feb 22, 2012 | 07:44 AM
But if the car was running fine before I started working on it I wouldn't think the catalytic converter is the problem for no spark,what do you think ?
Thanks for the prompt response
Old Feb 22, 2012 | 08:55 AM
should I try crank censer
