Wiring Harness Power Seat 2004 Sebring
I'm trying to disconnect the wiring harness connector under the power drivers seat in my sons' 2004 Sebring Convertible. I know it should be simple, but I can't see what tab to release the connector. I have tried searching the web, no luck there. Any ideas? Anyone?
If you are planning to remove the seat, you might have luck unbolting the seat first, then tipping it back so you can get a good view of the connector and how to deal with the tab. Most probably, in the assembly process, the harness is connected before the seat is bolted in, because it would be easier that way. Removal would be the opposite process.
I’m curious why you are doing this? I ask because I have clicking noise that I thought was coming from under dash but as I’ve checked closer, it seems to be coming from under my driver’s seat??? Sometimes when I brake, sometimes acceleration, and only after warmed up about 5 mins
