2002 Chrysler 300m random misfire
Old Mar 20, 2013 | 05:45 PM
mjrpayne's Avatar
Default 2002 Chrysler 300m random misfire
Car has a 3 liter v6 and cylinders 1, 3, and 4 are misfiring. Codes are p0351, p0353, and p0354. I've checked the voltage repaired the wiring to the (COP) which all now have 12 volts, but all 3 cylinders still misfire. Vehicle has a new PCM was installed before I acquired the vehicle. I've also swapped out each of the (COPs) on all 3 cylinders with other (COPs) and its still misfiring. Im out of options and scratching my head. Can anyone advise something new to try?
Old Mar 20, 2013 | 08:23 PM
u have 12v on one wire and a ground pulsing on the second wire do u have them both?
Old Mar 21, 2013 | 10:28 PM
mjrpayne's Avatar
yes it is
Old Apr 1, 2013 | 05:39 PM
LouKyWm's Avatar
Default 3.5L rocker arm assembly problems
Mine misfired had to get head rebuilt, replace water pump, camshaft seals and rocker arm assembly. Apparently there is issue with rocker arm assembly and when not caught and fixed it causes domino effect. all under manufacturer warranty mine 2010 47k mile
Old Apr 2, 2013 | 01:34 PM
mjrpayne's Avatar
After rechecking every thing over 4 time i decided to go to a junk yard and get a ecm ( i got the same part # or id # that the car calls for )for the heck of it and what do you know it fixed the problem. How ever another has came up now i think it has gone into security more after 3 starts and the car will not start it is not getting signal to the starter Now ive talked to 3 dealers 1 says ALL ecm's have to be programed to the car 2 say's they do not so im at a stumped point again and yes i have checked the starter and it is working properly anyone know witch is the truth ?
Old Apr 2, 2013 | 01:56 PM
the car has programed pin numbers into the computer u can swap them put the old one back on
Old Apr 2, 2013 | 03:45 PM
FIREM's Avatar
If you can get the SKIM and the key from the same car as the PCM (ecm) swap into your car all good. If not the Dealer will be needed to program your "new" one.
Sentry Key Immobilizer Module is located in the steering column at the key switch. It must match the PCM, and you can tape the key to it. This would avoid having to replace all key locks.
frayserboy4ever
Jan 27, 2012 03:17 PM
l.g0883
Oct 24, 2011 12:56 PM
brad walsh
Aug 18, 2011 11:20 PM
optimusprimer
Jul 23, 2009 10:33 PM
JJParr
Cirrus & Breeze
Nov 8, 2007 09:09 AM
