2006 chrysler 300c hemi..wont start!! HELP
Old May 26, 2016 | 03:03 PM
Cometmom1's Avatar
Default 2006 chrysler 300c hemi..wont start!! HELP
2006 300c hemi. Started fine, drove fine got home went to leave again and WILL NOT START. when turn key i hear a clicking like sound. All components working(radio lights etc). Just will not turn over to start. Car has a little more that 1/2 tank of gas. I did the turn key to on ac-on ac-on and NO codes!
I did notice the other day when i started it (it started just fine) that the fuel gauge went up dropped down and went back up to normal spot. Anyone have any input???
Old May 27, 2016 | 06:17 AM
UltraNutZ's Avatar
clicking as in like a low or dead battery? Just because the lights, radio, etc. work doesn't mean the battery is good.
I would start by checking the cables to the battery, both + and -. Lots of times you'll find your problem there in bad connections, loose connections, etc.
If no problem there, then I would remove the battery and bring to local auto parts store for load testing although I don't really trust them anymore to not try to sell you something you don't need. Then again the dealer is just as bad.
Old May 27, 2016 | 08:34 PM
Cometmom1's Avatar
Put battery charger on for about 20 mins. Started right up..pulled it in the garage. Going to leave battery charger on it for a few hours. Hoping all I need to replace is the battery!!
Old May 31, 2016 | 09:15 PM
hocus's Avatar
Had a similar issue recently turned out it was a worn battery, luckily I was able to get a replacement at 4 wheel online, got an Optima brand that claims to work longer compared with other brands.
Old Jun 1, 2016 | 02:55 PM
Cometmom1's Avatar
thank you. i am hoping that it is only the battery!!
RacingJunk
Jun 25, 2013 05:19 AM
BuzzA
Oct 28, 2011 11:41 AM
mrhaney
Mar 8, 2008 12:11 PM
larrynipon
Nov 7, 2005 09:27 PM
Apr 21, 2005 09:54 PM
