2009 330T missing on Number 3 if…….
Old Mar 2, 2023 | 09:27 PM
Duds's Avatar
Default 2009 330T missing on Number 3 if…….
2009 Chrysler 300, 3.5 engine. (80,000 miles) Cylinder 3 missing. Receives P203 code.
When engine started from engine cold it will run without any issue. After car driven and it warms up and then shut off, and immediately restarted no issue. But if I wait even 5 minutes P203 returns.
If started from cold engine it can be driven for hours without P203 or missing cylinder. If I shut it off and restart 5 minutes later P203 returns.
Using nerd light verified pulse present at number 3 injector.
New coil pack connector #3
New pcm
New injector #3
new connector #3 injector
Coil pack on #3 swapped with #1
Replaced upper and lower gaskets on intake and plenum
Any ideas before the engine is removed or the car is traded in?? From what I understand engine needs removal for valve train work. Any help would be most appreciated.
Duds
Dec 11, 2024 02:29 PM
Sind
Apr 6, 2017 12:37 AM
leclaire808
Aug 21, 2016 02:28 PM
firevia
Jun 3, 2016 10:23 PM
preacherpat2001
May 2, 2013 04:43 PM
