P0203 only after warm start.
Old Oct 21, 2022 | 02:20 PM
Duds's Avatar
Default P0203 only after warm start.
2009 Chrysler 300 3.5.
I can drive the car all day long just fine as long as I do not shut it off. If I shut off the engine and immediately restart, no problem as well as starting the car 2 hours later. No codes.
If I start the car 5 minutes after shutdown or an hour after shutdown I get a P0203 and a miss on cylinder 3.
replaced injector #3
swapped ignition 3 coil from another cylinder
ohmed from output of PCM (pin 7) on C2 to PCM (pin 12) injector control of C2 on PCM. All readings consistent with other cylinders. This sure seems like a heat issue with the PCM to me. But how to prove it before ordering a PCM and possible waste of $?
thanks!!
Old Dec 11, 2024 | 02:29 PM
Flowerdriver's Avatar
thanks!!
I'm having exact same issue ..... Was there ever a solution other than replacing the injector?
Gutterbubba
Nov 2, 2015 12:38 PM
MattStrike
Mar 22, 2013 04:52 PM
db2552
Feb 25, 2012 02:08 AM
tc187211
Oct 25, 2011 09:45 PM
ETD66SS
Jan 29, 2007 10:39 AM
