2012 300 limited
Old Aug 29, 2019 | 01:24 PM
claydo's Avatar
Default 2012 300 limited
Can anybody tell me if a bad (driver side) rear wheel bearing would make the car pull to the right.
Seems like when I drive around 8 - 10 miles, it starts to pull to the right a little.
Rear driver side hub is very warm to the touch, other side cool...
Thanks.
Old Aug 29, 2019 | 02:02 PM
BiliTheAxe's Avatar
Yes it can, and also t could be an emergency brake or binding caliper on that wheel.
When a drivers side rear wheel has resistance turning, it will cause you to have to turn the wheel to the right to compensate for the drag.
Old Aug 29, 2019 | 02:26 PM
jtcooks's Avatar
Better fix it before get hurt dude
Old Aug 29, 2019 | 04:27 PM
claydo's Avatar
Thanks for the info,
The car pulls to the right so I must have some other problem...
Your saying with a bad left rear bearing, you would have to steer to the right to compensate...
Old Aug 30, 2019 | 12:02 PM
BiliTheAxe's Avatar
Whichever side the wheel wants to turn towards is the side with the problem, with no hands touching the wheel. The drag forces you to turn the wheel towards the opposite direction to compensate.
If the wheel turns itself to the left as you drive, then the problem is on the left.
Old Aug 30, 2019 | 12:07 PM
claydo's Avatar
Thanks, I got it now... I'll be checking the rear bearings and also the e-brake for drag...
Thanks again...
SadSack
Cirrus & Breeze
Feb 23, 2013 06:46 AM
myke212
Cirrus & Breeze
Apr 12, 2011 12:08 PM
muddauber5.7
Mar 21, 2011 03:01 PM
Whitepaci06
Mar 5, 2008 12:05 PM
simonda
Nov 17, 2007 07:25 AM
