2012 Chrysler 300-OBD Code 850
Hey Guys! My 300 has thrown the code P850! I've had one shop tell me that there is a timing issue. It will turn over but it will not stay running. The charge to fix my car is nearly $2,000! I don't want to be ran over by these guys. Any suggestions?
engine size? the p0850 is a park neutral safety switch performance not a timing issue
The engine size is 3.6l V6. Oil has leaked into the cylinder.
then the oil leak would be from warped heads or something like that still not a timing issue
Oh okay. When you mention heads are you meaning cylinder heads? I noticed when I pulled the spark plug out of the cylinder 5 it was bent at the end as if something has hit it.
