2014 300c loud road noise
Old Aug 5, 2022 | 02:18 PM
elkermarty's Avatar
Default 2014 300c loud road noise
When traveling on our city streets I have a very very loud noise. This sounds like there is no shocks. This ha just happened. My 2017 Jeep GC is so much quieter. I do not want to start hanging on parts one at a time until the noise is solved. Any help???
Old Aug 5, 2022 | 05:13 PM
tarhealcracker's Avatar
Not much background info to work with here but if it just all of a sudden started I would have your wheel alignment checked. Described this noise if you can.
Old Aug 8, 2022 | 04:07 PM
"This sounds like there is no shocks." Shock absorbers do not exist to reduce noise. They are there to control jounce and rebound of the springs. Removing the shocks should not produce any noise but would make the ride otherwise uncomfortable.
If it's a banging noise, you'll have to get under there and inspect your suspension carefully for broken parts. You could also have accidentally picked up some stray piece of road debris that is causing some noise. In any case, the answer is to get under there and look at the car carefully.
JC300
Jun 17, 2021 09:37 AM
Kabstyle
Nov 11, 2019 02:47 AM
kevincutch
Aug 21, 2019 03:28 PM
noocha2b
Oct 29, 2009 03:27 PM
MOHAMMEDHU2003
Jul 22, 2005 04:51 AM
