Automatic Headlamps
Does anyone know if Chrysler makes something to convert to Automatic Headlights in a 300 Touring. Thanks
RE: Automatic Headlamps
nope expensive
easy to do: and FREE.
How to get FREE Auto Headlights for your Magnum. written by Token Note: You will still need to have the climate sensor installed. 1. Remove the headlight switch from your Magnum, it just pops out using a trim tool or butter knife. http://www.lxforums.com/images/How_T...eadlight/1.jpg 2. Insert the end of a small screwdriver directly opposite the indicator mark on the switch and pry the knob off. http://www.lxforums.com/images/How_T...eadlight/2.jpg 3. Identify the detent located at the furthest right position (this is the one that will have to be removed) http://www.lxforums.com/images/How_T...eadlight/3.jpg 4. Using a Dremmel tool remove the detent so the switch can be turned one click further to the left (where the “A” would be. Be sure to protect the insides of the switch so no material gets into the inner workings. http://www.lxforums.com/images/How_T...eadlight/4.jpg 5. With the detent removed the switch will be able to turn to the “A” position http://www.lxforums.com/images/How_T...eadlight/5.jpg 6. Clean up the switch, and re-install the selector knob. http://www.lxforums.com/images/How_T...eadlight/6.jpg 7. Re-Install the switch and enjoy your FREE mod. You now have AUTO HEADLIGHTS. 8.You may have to reset the car’s computer by removing the negative battery cable and re-attaching. If you need to do this remember to reset the ESP and Auto Window Switch (if so installed) |
