Automatic Headlamps
Old Nov 24, 2006 | 02:58 PM
hkalin's Avatar
Default Automatic Headlamps
Does anyone know if Chrysler makes something to convert to Automatic Headlights in a 300 Touring. Thanks
Old Dec 15, 2006 | 02:03 AM
Default RE: Automatic Headlamps
nope expensive
Old Dec 19, 2006 | 02:08 PM
mr. incredible's Avatar
easy to do: and FREE.
How to get FREE Auto Headlights for your Magnum.
written by Token
Note: You will still need to have the climate sensor installed.
1. Remove the headlight switch from your Magnum, it just pops out using a trim tool or butter knife.
2. Insert the end of a small screwdriver directly opposite the indicator mark on the switch and pry the **** off.
3. Identify the detent located at the furthest right position (this is the one that will have to be removed)
4. Using a Dremmel tool remove the detent so the switch can be turned one click further to the left (where the “A” would be. Be sure to protect the insides of the switch so no material gets into the inner workings.
5. With the detent removed the switch will be able to turn to the “A” position
6. Clean up the switch, and re-install the selector ****.
7. Re-Install the switch and enjoy your FREE mod. You now have AUTO HEADLIGHTS.
8.You may have to reset the car’s computer by removing the negative battery cable and re-attaching.
If you need to do this remember to reset the ESP and Auto Window Switch (if so installed)
Liznims
Feb 28, 2015 07:21 AM
frizzby5
Jan 7, 2014 05:36 PM
janoush
Dec 7, 2012 01:02 AM
knubbis2
Apr 10, 2011 08:59 PM
sinisterseagull
Oct 7, 2009 09:16 PM
