A/C Not Holding Temperature
Old Jan 19, 2023 | 11:01 AM
eschroeter's Avatar
Default A/C Not Holding Temperature
When I start the car and the car has warmed up, the air conditioning blows hot air no matter what the temperature setting. (This isn't the situation about blowing hot air on the driver and cold air on the passenger; it is hot air throughout). Sometimes I can solve it by turning the temperature all the way down to LOW. Sometimes I can solve it by turning the A/C off and then back on.
Other times it will blow cold air no matter how high I set the temperature setting.
Bottom line, it seems that I don't have control over the temperature setting more often than not.
What can I look at?
Old Jan 19, 2023 | 03:09 PM
single or dual air temp control ?
Old Jan 19, 2023 | 03:19 PM
eschroeter's Avatar
This is a 2012 Chrysler Limited with Dual temp control.
Old Jan 22, 2023 | 09:46 PM
there will be 2 motors for the blend air take them off and see if the doors is broke if you can turn the **** all the way around also look at the gear at the motor
janssoner
Mar 23, 2022 02:55 PM
skid2964
Jul 29, 2014 02:11 PM
fbongo
Jul 17, 2013 02:46 PM
mikejw
Jan 2, 2013 02:45 PM
04Pacifica393
Jul 13, 2009 09:29 AM
