Changing EGR Valve 2006 3.5L Limited
i have a check engine light and a 404 code on my 2006 300 Limited 3.5L. i have a replacement and a gasket for the upper intake, along with the service manual. Is there anything in particular that I should look for or do while changing the EGR? Any tips or tricks?
Thanks in advance!
Thanks in advance!
I did the job today, so far so good. I decided to change the spark plugs too, just in case. The car has 61K miles so it wasn't due, but I thought that with having the CEL on for a while, if there was any chance that there had been any issues, I'd rather change them while I had the upper intake removed.
I reviewed the manual and took my time, probably spent about 3-1/2 hours from disconnecting the battery to test-driving. It wasn't too bad if you have a decent array of tools. There were no really problematic steps, just some tight quarters. I couldn't see changing it from underneath the car with the upper intake in place, it would seem to be way too tight, but people have said they did it that way.
griffinel
12
Feb 16, 2011 07:42 PM
