Humidity sensor ?
Old Aug 7, 2018 | 07:08 AM
tarhealcracker's Avatar
Default Humidity sensor ?
I have a 2012 300c with the auto climate control system. Regarding the Humidity Sensor, what does it do.? What is it's function.?
Old Aug 9, 2018 | 04:33 PM
I'm on 2 Chrysler 300 Forums and I can't get an answer to this question. What's up with that?
Old Aug 11, 2018 | 01:19 AM
there is no such thing as a humidity sensor temperature yes humidity no
Old Aug 11, 2018 | 06:42 PM
I don't understand this . I have read posts regarding guys replacing their Humidity sensors and seen the procedure on u tube, etc . And then there are posts on various Forums re guys trying to troubleshoot their AC systems that talk a lot about the "humidity" sensor issue. What's up?
Old Aug 12, 2018 | 08:32 PM
Humidity is the amount of water in the air. the car does not car how much humidity is in the air even in an AC system
Old Aug 13, 2018 | 06:03 AM
Polarzak's Avatar
Hello Tarhealcracker. Nice to see you here. It is a google free zone. Sure there is a humidity sensor, despite what Chrysler Tech says. I have noticed when the humidity is high, the compressor will kick in, even though I have not set the temp to call for AC. Note the attached wiring diagram bottom right corner....HUMIDITY SENSOR.
Old Aug 13, 2018 | 06:07 AM
Back to my question, why does the car have a "humidity sensor" and what does it do?
The literature for my car describes the system as "Automatic Dual Zone Temperature Control with humidity sensor" quote/unquote. I must say Chrysler Tech that you are being less than helpful. Responding to your posts in order:
1. The car does in fact have a "Humidity Sensor".
2. I understand the definition of Humidity is the amount of water in the air.
Come on now. Are you putting us on?
Old Aug 13, 2018 | 06:23 AM
Thanks for the response Polarzak.
I'm not sure what's going on with Chrysler Tech. He has been most helpful in the past and heaven knows we need as many pros as we can get on this Forum.
Old Aug 13, 2018 | 01:14 PM
Polarzak's Avatar
The integrated temperature humidity sensor factors humidity in to the climate control to use only as much A/C as needed. If the temperature outside is 80F and the humidity is 80 percent, the system will control the temperature to a lower level than if the humidity was only 30 percent.
Old Aug 13, 2018 | 03:14 PM
Wow. Outstanding. So the AC has an algorithm it uses to promote temp vs humidity comfort. My guess is that "recirculate" is in the tool box as well.
