Mich
my son have a 2006 Chrysler 300t, and I loaner my diagnostics OBT II tool, he pull 2 codes, 1.- P 2638 and 2.- P 2173,:confused: now how I can check this sensors, and where this sensor are located, I just to be a Tech with Chrysler until 1998, or whay is the next proceed.
Thanks. Mich Tuolumne, Ca. |
I am gonna haft to say this just because u are a former tech one question how much oil goes into a XXXX engine??? and what kinda 300 is it?? what engine size????
Chrysler Tech.
Ok I answered your question, according to the shop is 5.5 qts. then is a 3.5L & 300T remember Chrysler take over American motors, Jeep, I just to work on Jeeps, also some Chrysler and I my major training was at Ontario, Ca. like I said before I stop working on 09/98, so please any tip(s) for this 2 codes. Thanks. Mich |
P2173-HIGH AIRFLOW/VACUUM LEAK DETECTED (SLOW ACCUMULATION
P2638-TORQUE MANAGEMENT FEEDBACK SIGNAL PERFORMANCE Theory of Operation The Transmission Control Module (TCM) requests torque reductions over the CAN bus during a transmission shift to improve shift quality. The TCM verifies that the PCM / ECM has performed the requested torque reduction by monitoring the response to the request. If the response is not within a specified tolerance, the TCM increments a counter, and if this counter reaches a threshold, the DTC sets. When Monitored: Engine intervention active for at least 20 ms, no engine torque errors, engine torque demand is greater than 0. Set Condition: Torque Reduction acknowledge bit - not set, no shift aborts, the error flag Torque Reduction Acknowledge is not set, Powertrain controller not supporting torque requests. Possible Causes CAN BUS CIRCUIT DTC PRESENT TRANSMISSION CONTROL MODULE POWERTRAIN / ENGINE CONTROL MODULE |
