P1005
Old Apr 1, 2024 | 08:56 PM
adamamari's Avatar
Default P1005
Hi all I have a 2007 300 2.7 and I have a code p1005 I cleaned the valve and installed it code came back replaced the valve code came back, I’ve also seen some have had pcm issues so I replaced that code came back any ideas or anyone ran into this before?
Old Apr 2, 2024 | 02:08 PM
Jake Turner's Avatar
Which valve? What's the code description?
Old Apr 2, 2024 | 02:14 PM
adamamari's Avatar
p1005 -manifold tuning valve performance
Old Apr 2, 2024 | 02:24 PM
I have a 3.5 so my questions might not make sense.
Did you ensure the mechanism is moving freely when you had the valve off?
Did you inspect the wiring carefully for breaks, cracks or chafing?
Did you check the pins in the plug looking for bent or loose pins?
Did you use good quality parts?
Did you try disconnecting the battery after installation to maybe clear the code?
Don't know if this will help, but these are the basic first things I would look at, hope it helps.
Old Apr 2, 2024 | 02:29 PM
adamamari's Avatar
the part I got from eBay so not sure if it’s good but all the other stuff I did do I actuated the valve using a scanner and it turns freely and every single time without missing a beat, wiring seems good but I can’t see under the intake manifold which is where the wiring runs, I changed out the pcm because all tests I did point to that, would it be possible that a clogged intake manifold would cause this? Other than that I’m going to order an Autozone Dorman manifold valve and throw that on and see if it fixes jt
Old Apr 2, 2024 | 02:41 PM
Did you activate the valve un-installed? If so, it worked ok? Did you attempt to turn the mechanism that the valve controls?
I guess the manifold could be gunked up, but not plugged, the car wouldn't' run.
If none of the things you have tried worked, my next step would be a known good shop.
I don't condone the "throwing parts" method of repair. But even more than that, I don't condone using AutoZone for anything. JMHO.
Hiver12
Mar 29, 2022 12:18 PM
Leticia Allison
Aug 1, 2017 12:14 PM
Demonesque
Apr 22, 2011 03:52 AM
paris
May 8, 2010 10:16 PM
RBlatt6011
Jul 25, 2008 04:42 PM
