replaced timing chain now wont start
Old Jun 24, 2021 | 07:02 PM
  #21
get a cam or crank sensor code? when you did the timing did you replace the cam sprockets?
Old Jun 24, 2021 | 07:42 PM
  #22
trkenn's Avatar
only code i pull is for the A/C i have replaced cam sensor but have not put on crank sensor. no I did not change cam sprockets, this would also not explain why it ran before the starter burned up. I will say it again, it turns over, there is no spark it ran before the starter burned up, it is not the timing it is not the compression it is not a seized motor IT RAN BEFORE THE STARTER BURNED UP AND NOW THERE IS NO SPARK. thank you.
Old Jun 26, 2021 | 09:38 AM
  #23
tarhealcracker's Avatar
Trkenn old boy. I think you have come to the limit of how much help you cam expect from this forum. Me thinks it's time to find a Chrysler tech with some real diagnostic skills.
Whatever you decide, stay with us as we are really interested and invested in you and your car - most particularly
"where is the spark" ?
Old Jun 26, 2021 | 10:14 AM
  #24
trkenn's Avatar
I have to agree with you as the help, although may have been well meaning has been no help at all.
Old Jun 26, 2021 | 07:42 PM
  #25
This is how many problems with cars are resolved and finding the issue at hand.
First was the issue there before any work was done? if not then its likely human error with the Occom's razor rule.
on you scanner can you see cam and crank in sync?
Old Jun 29, 2021 | 08:55 AM
  #26
So Trkenn - What is your next step ? What is the plan ?
Old Jun 29, 2021 | 09:17 AM
  #27
trkenn's Avatar
I have no plan. I will try the crank sensor but other than that I have been given no idea what the problem is or could be. I am sure it's electric because it ran before I burned up the starter. But of course "it's seized up" "it's the compression" "it jumped time" " you don't have a manual" all good ideas except if it ran before starter burned up, it's not seized, it has compression, so I don't know what to think. Only code I get is for the air conditioner and last I checked a motor will run with out that.
Old Jun 29, 2021 | 12:37 PM
  #28
Well poor old you. You couldn't get someone else to solve the problem so ya get Snarky with those who tried to help. Stop that..
Sit up. Stand up. Make a plan and move forward. You are on your own. You get right down to it, that describes us all. Don't you think ?
Old Jun 29, 2021 | 01:04 PM
  #29
trkenn's Avatar
Snarky? I said they were well meaning but not helpful just as you asked a question I answered. But yet you provided no help to the situation as well. Since I'm being snarky please explain to me how compression timing or a not seized engine that ran before the starter burned up solves my problem? Snarky? people need to read before answering.
Old Jun 29, 2021 | 02:09 PM
  #30
At the end of the day you're the guy with the problem and no plan. I'm a guy with a mouse signing off this Thead. Good luck to ya.
