Right high beam not working after replacing the bulb and fuse
Old Apr 12, 2023 | 06:14 PM
Omarr's Avatar
Default Right high beam not working after replacing the bulb and fuse
Good afternoon/evening everyone.
I have 2007 Chrysler 300 , v6 2.7. the right side high beam is not working. I replaced the bulb, checked the fuses and still not working. Anyone has/had a similar issue?
Old Apr 13, 2023 | 09:15 AM
ggoose's Avatar
Had a similar issue on an '06 Charger with the left side high beam. The problem was with the ground wire where it was spliced into the chassis ground. The chassis ground should be close by but it is a bit of a pain to trace and access. Patience is required.
Old Apr 13, 2023 | 11:01 AM
Omarr's Avatar
Thanks for taking the time to read and respond to my post.
I just came home from my local mechanic who said that there's a power but once he "plugs the bulb the power go to the ground". He said he'll trac the wire because its damaged somewhere.
turbopilot51
Jan 26, 2014 02:28 PM
scott04
Dec 16, 2009 08:41 PM
3.3lxbluevan
Mar 18, 2009 07:55 PM
kmatwill
9
Apr 1, 2007 03:52 PM
Elvis
Jan 15, 2006 06:44 AM
