starting problems
Old Jan 22, 2007 | 06:04 PM
vivsor's Avatar
Default starting problems
I just needing some HELP!!!I have a Chrysler 300 M 2001 which I love but I'm having starting problems..let me try and tell you...sometimes when I go to start my car it just cranks and cranks but does not start then I wait a few seconds and it will start but then I can smell gas ....I have taken it to the dealership and they put a new fuel senor in but it hasn't helped...this problem happens in good or bad conditions.., they tell me the problem isn't happening enough for them to get a CODE....is anyone else having this same problem any information would be great!!!!!!
Old Feb 5, 2007 | 04:36 PM
YellaDawg's Avatar
Default RE: starting problems
I am having the exact same issue with my 2001 300M. It started just a few weeks ago. When I took it into the dealer, they claimed they saw no problem and no fault codes came up in the diagnostics.
Old Feb 5, 2007 | 09:07 PM
vivsor's Avatar
Sorry your having the same problem GOOD LUCK!!!! I have been trying to get my car fixed for 3 months now, finally I have it at a shop in the town where I live it right now as we speak so if I get a answer from there I will let you know...he seems to think it has something to do with the presure it's to high it needs to be 51 or below and my car is at 65 pounds not sure what that means I should get it back by wednesday hopefully I will keep you posted
Old Feb 5, 2007 | 10:20 PM
YellaDawg's Avatar
Thanks, I'll be looking for your solution
Old Feb 5, 2007 | 11:14 PM
that would be fuel pressure and that wont cause a no start only low pressure not high.
Old Feb 6, 2007 | 12:25 PM
vivsor's Avatar
so what is causing the problem then ??????any ideas....
Old Feb 6, 2007 | 01:14 PM
i have not seen this issue in my shop so with out looking at it no
Old Feb 6, 2007 | 01:16 PM
vivsor's Avatar
thanks .....
Old Feb 12, 2007 | 02:47 PM
YellaDawg's Avatar
Hi, Did you get your car back? Was the problemm fixed? What repairs were made?
Old Feb 12, 2007 | 06:52 PM
vivsor's Avatar
yes I got my car back and it is working fine now....the mechinic said that the fuel injectors were probably clogged up so he had me put some TECHRON in the gas tank..the 1st tank I put in 2 bottles of TECHRON and the second tank I put in one bottle it seemed to help I went to Vegas back with no problems at all...so I hope it is cured!!!!! you can get TECHRON at any chevron station it cleans the fuel injectors....
