08 Aspen 5.7 Hemi Fuel Pump Problems
Is there any way to access fuel pump with out Droping Tank?
Any Isnside Hatch that I have not found? New fuel pump installed by Mech. Gauges work Backwardss when gas tank is filled the gauge reads empty - As the gas run out the Gauge says 1/4 tank left when its actualy 1/4 tank used. Mechanic out of Business. Will fix myself !!! |
Looks like you're going to have to drop the tank and completely remove the (new) fuel pump to get to the fuel level sending unit. Did the (out of business) mechanic use OEM parts, or cheap crap that might be wired incorrectly? Could be as simple as moving the float arm to the other side (if reversible), or could be a wiring issue.
That style lock ring is a sonofa... to break loose. You WILL need a breaker bar and the tool. Don't try to hammer and screwdriver it, you could mess up the tank or get the ring bent crooked
| All times are GMT -5. The time now is 01:09 AM. |
