08 Aspen 5.7 Hemi Fuel Pump Problems
Old Apr 11, 2012 | 08:41 PM
acelimo1960's Avatar
Default 08 Aspen 5.7 Hemi Fuel Pump Problems
Is there any way to access fuel pump with out Droping Tank?
Any Isnside Hatch that I have not found?
New fuel pump installed by Mech.
Gauges work Backwardss when gas tank is filled
the gauge reads empty - As the gas run out
the Gauge says 1/4 tank left when its actualy 1/4 tank used.
Mechanic out of Business.
Will fix myself !!!
Old Apr 12, 2012 | 07:45 PM
15951a\'s Avatar
Looks like you're going to have to drop the tank and completely remove the (new) fuel pump to get to the fuel level sending unit. Did the (out of business) mechanic use OEM parts, or cheap crap that might be wired incorrectly? Could be as simple as moving the float arm to the other side (if reversible), or could be a wiring issue.
  1. Drain and remove fuel tank.
  2. Note rotational position of module before attempting removal. An indexing arrow is located on top of module for this purpose.
  3. Position Lockring Remover/Installer 9340 into notches on outside edge of lockring.
  4. Install 1/2 inch drive breaker bar to Lockring Remover/Installer 9340.
  5. Rotate breaker bar counterclockwise to remove lockring.
  6. Remove lockring. The module will spring up slightly when lockring is removed.
  7. Remove module from fuel tank. Be careful not to bend float arm while removing.
Old Apr 12, 2012 | 10:51 PM
TNtech's Avatar
That style lock ring is a sonofa... to break loose. You WILL need a breaker bar and the tool. Don't try to hammer and screwdriver it, you could mess up the tank or get the ring bent crooked
Darth Menace
Feb 19, 2016 09:16 PM
RacingJunk
Jun 25, 2013 05:19 AM
96BTC
Sep 27, 2010 10:29 PM
jcl_cls01
Aug 3, 2009 04:05 PM
streetwise
Oct 29, 2007 10:23 AM
