2009 Aspen Hybrid radiator fan problem
Old Jan 5, 2020 | 02:30 PM
James Buchy's Avatar
Question 2009 Aspen Hybrid radiator fan problem
Hi
My employer has asked me to look into a problem with his 2009 Aspen Hybrid. The radiator fan will not stop after the vehicle is shut off. it will keep running at full speed until the battery dies or is disconnected. Because there were so few built I am having a real hard time finding anyone with information. Does anybody here have any suggestions?
Old Apr 21, 2020 | 07:22 PM
TeamE's Avatar
Default Fan running after shut off, draining battery
Did you get an answer to your problem? I seem to be experiencing the same with my 2009 Hemi Hybrid. Thanks for any input.
Old May 25, 2020 | 08:29 PM
Genghis's Avatar
Default Fan wont turn off
Hi all, I am having the same issue with my 2009 Aspen Hybrid. It first started as a dead battery, then still occurs now after replacing the battery. I removed both relays titled rad fan low and rad fan high with no change, the fan remains running.
If anyone has managed to figure this out, would appreciate any guidance.
Many thanks
Old May 26, 2020 | 05:27 AM
Aenglese's Avatar
Default I took mine to chrysler
They said I need to replace the hybrid gateway module and the cooling fan - I don’t think the cooling fan has an issue because that is running right but it’s signal is coming from the gateway module (not a mechanic but)
Old Jun 8, 2020 | 09:37 AM
Aenglese's Avatar
so check this out —-> I have your solutions it’s two parts it’s the gateway module and the hybrid cooling fan BUT THEY DONT MAKE THE HYBRID COOLING FAN ANYMORE so what you can do which is what I’m doing is taking part 55361429AC and using the housing but replacing the fan inside of it with the fan of a bmw 600w fan motor so it will work
Dan400Man
Dec 4, 2019 12:28 AM
Chrysler Information
Jan 4, 2018 07:03 PM
Bob R.
Aug 29, 2017 06:23 PM
Railroader85
Nov 29, 2016 11:39 AM
mparsons1
Mar 29, 2012 06:58 PM
