AC is not cold when sitting idle
Old Aug 9, 2010 | 03:47 PM
jcl_cls01's Avatar
Default AC is not cold when sitting idle
Is it common that the AC on the Aspen is not cold when the vehicle is sitting idle in one spot? It eventually gets cold when the vehicle is in motion, but not idle.
Old Aug 9, 2010 | 09:27 PM
that would be typical low freon or the fans are not working
Old Aug 10, 2010 | 07:38 AM
kkreit01's Avatar
I'd say if it's 95-100+ degrees, that's typical.
Old Aug 11, 2010 | 11:59 AM
str8hemi's Avatar
I just noticed that same issue on my 07. I'm going to check the freon this weekend. If I buy a set of gauges what should they be reading at?
Old Aug 25, 2010 | 05:19 PM
str8hemi's Avatar
well I took my truck to a friend who works on cars and he said that I have enough freon in the system and that fan is working properly. I did notice though that if i'm parked somewhere and air doesn't get cold as soon as i tap on the gas pedal to raise the rpms the air starts to get colder. I'm not sure but i'm guessing my fan might be a little week. I'm going to look further into that
Old Aug 25, 2010 | 10:06 PM
15951a\'s Avatar
In my experience, auto a/c is never as cold at idle as it is when you're in motion. Until you get air moving over the condenser, the air doesn't seem to really get ice cold.
When our weather gets into the 90s, the air will be cool, but not cold at idle. It takes movement to really get the system blowing cold air.
The volume of air being put out can also have an impact. Is it colder on lower fan speeds at idle?
Old Aug 26, 2010 | 04:54 AM
str8hemi's Avatar
wether its at low speeds or high the air doesn't seem to be blowing cold while at idle. Only when I press the accelerator to raise the rpms does it start to get cold. But as soon as the car is rolling it will blow ice cold
Old Sep 19, 2010 | 11:02 PM
cruzinquick's Avatar
Default A/C
I just took mine in to dealer for this issue. They replaced the module that switches between heat and cold. I tried to find the invoice but couldn't find it. At first they actually wrote down on the return invoice that the air passing over the condenser has to be moving in order to cool. That's unacceptable in this vehicle. It cools better but still no match to the cooling in my avalanche and crossfire sitting still. Moving it chills nicely, but even at at stoplight it begins to warm up. I'm in AZ where it was 109 today, and it's insufficient. Definitely not a quality of the Aspen or maybe Dodge, Chrysler altogether.
Old May 30, 2020 | 09:28 PM
buddylove35's Avatar
Post
hello so im having the same problem right now , so are y'all saying that is this normal for the car ac to rise up when the car is idle , I seem to find that to be very weird , I was thinking something was wrong with my chrysler 300c 5.7 but I am looking for more info about this ac problem please ..
Chrysler Forum Editor
May 21, 2014 03:35 PM
Exiled4Now
Other
Dec 1, 2013 09:41 AM
Discovering06
Jan 28, 2011 07:21 PM
99CHRYSLHS
Sep 19, 2010 12:41 PM
john1962
Oct 8, 2008 11:44 PM
