Annoying squeeking from front of 08 Aspen
Anybody out there got an annoying squeekin from ur Aspen? I have been trying to track this down for a while with no luck. Ive tried spray lubricants at various points underneath. On ours, it has those two bars/rods that u can adjust for ride height/stiffness? It sounds like it might be towards the front of vehicle for them, i tried to grease em, i think it worked for just a short while? It squeeks over bumps, speedbumps, left/right of steering wheel...any ideas are appreciated...thanks.
On my 08 Aspen I had an annoying squeak everytime I turned the steering wheel more than a few degrees each way. In the footwell, near the pedals, where the steering shaft(?) meets the floor I sprayed some WD40 there and it solved the problem. I know your problem sounds a little different but just letting you know what I experienced with mine. If you want any more detail let me know and I will take a photo of the part i'm talking about when it's light tomorrow.
Originally Posted by Solaris
(Post 104328)
Originally Posted by wtygart
(Post 104260)
I too are late to reply but my 08 Aspen had a terrible squeeking issue up front, like an old squeaky bed, found that the front torsion or stabilizer bar bushing were the problem. Purchased a set of poly bushings, noise gone, simple install and cheap, under 20 bucks and 4 bolts and a little prying to remove old bushings.
Same with mines. First drive I heard a squeaking sound driving over dip. Had to take it to shop for wheel bearing and they replaced the stabilizer bushings and both end links and when I picked it up haven't heard a suspension noise since!
