-   Chrysler Aspen (https://www.chryslerforum.com/forum/chrysler-aspen-41/)
-   -   Anyone try using a performance chip? (https://www.chryslerforum.com/forum/chrysler-aspen-41/anyone-try-using-performance-chip-6479/)
HotSS Sep 17, 2008 09:39 AM
I saw one from Jet. It is 250 bucks, and I am wondering if it is worth it and what gains you got.
swittie Sep 17, 2008 05:35 PM
RE: Anyone try using a performance chip?
I was suckered into the 9.99 and 19.99 versions on ebay. Both bypass your mass-flow air sensor and fool the ECU into thinking the air is cool, setting advance and mixture as such.
Neither worked, and one tripped the check engine light. Luckily I have a code computer and could reset and remove.
Beware.
valleybill55@aol.com Sep 17, 2008 06:52 PM
the hemi has got all the power i needand with the highgas pricessometimes that is to much.
Al B Sep 18, 2008 07:47 PM
No kidding! Anyone got a fuel economy chip? lol Is the confusers in the Aspen the same as in the Rams? My buddy had a fuel economy chip in one of his Rams and found better economy, but poor power, at least to what he was used to with out the chip.
ORIGINAL: valleybill55@aol.com
CHRYSLER TECH Sep 20, 2008 10:38 AM
the toss up of power and MPG will ALWAYS BE THE SAME.
This will never change with a gas burner. If u want power u will have lower MPG if u want higher MPG u will have lower power.
Al B Sep 20, 2008 10:53 AM
ditto, there is always a cost!
ORIGINAL: CHRYSLER TECH
bjs-performance Jun 21, 2010 08:32 AM
Not always true! I have a tuner on mine for better gas mileage and it provides more power than stock at the same time. The tune also allows me to use 87 octane now instead of 89 octane which saves money at the pump. You also have the option of buying a tuner that will let you tune for better gas mileage and then switch the tune to performance when you want. If your interesed give me a call and I'll sell you one for about $350.
760-267-3288
-Jeremy
sales@bjs-performance.com
BIG JERMS PERFORMANCE
kkreit01 Jun 21, 2010 09:16 AM
I would stay way clear of the ebay scams. JET typically doesn't review well either. The SCT-type tuners are typically well-praised in most all applications.
CHRYSLER TECH Jun 21, 2010 09:54 AM
BJS u cant change the laws of physics like that if U get more power u haft to use more air and fuel thus lower MPG if U get more MPG u lower the amount of fuel going into the engine its a toss up
the top fuel drags the 340 mph ones turn over 8000 HP they go through about 25 gals per run.
15951a\ Jun 21, 2010 07:46 PM
760-267-3288
-Jeremy
I don't buy it.
1. You're trying to sell a product.
2. If there was a way through simple programming to increase MPG and power, it would already be programmed that way.
If you've found a way to get more power with lower octane and better mileage, there has to be a trade-off somewhere. Engine longevity is probably one of them.
