Aspen gear selector readout and radio remain on
I searched and found nothing on this, but I'm hoping someone else might have an idea what the problem could be. More often than not, when I turn the ignition off, the gear selector readout on the dash remains on and when I go to exit the truck, the door chimes like I've left the keys in the ignition. I have to put the key back in and jiggle it a little before it recognizes that the ignition is actually off. Anyone else have this problem? Is it the ignition switch going bad?
TIA! |
Can you please provide more details, i.e. what model year vehicle are you referring to?
What type of engine is the vehicle equipped with? Are there any fault codes? etc. |
Originally Posted by ChryslerCares
(Post 80444)
What type of engine is the vehicle equipped with? Are there any fault codes? etc. It's an '07 Aspen 4.7L flex fuel. Approx 85K miles. We've owned it since 2007 and have always had the occasional problem of shifting to reverse and having it slip back into neutral but this problem seems separate from that. No fault codes. |
That sounds like it could be an issue with the key-in ignition switch and/or the ignition key cylinder. Do you have a lot of weight on your key ring?
Originally Posted by 15951a\
(Post 80574)
If putting the key back in the ignition switch and jiggling it cures the problem, it sounds like the ignition key cylinder is worn and needs to be replaced.
(Post 80601)
Originally Posted by Amy Brown
(Post 80484)
After some investigation, the vehicle may need to have the PCM software updated. Below is a service bulletin that may help resolve some of the concerns your experiencing. I've included it below for your review: TSB 18-035-07 SUBJECT: FLASH: 545RFE Transmission Defaults To Neutral OVERVIEW: This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software. NOTE: This bulletin applies to vehicles equipped with a 545RFE transmission (sale code DGQ) built on or before March 26, 2007 SYMPTOM/CONDITION: The transmission may default into neutral gear if the transmission gear selector is moved into “reverse gear range” under certain operating conditions. The default into neutral gear is done to protect the transmission mechanical components from potential damage. New PCM software will monitor transmission hydraulic pressure and allow reverse gear engagement, if the transmission is in “reverse gear range” and the transmission hydraulic pressure is sufficient to support reverse gear operation. Labor Time = Aproximately 0.4 Hrs. |
(Post 80413)
TIA! https://dodgeforum.com/forum/3rd-gen...ml#post3586344 |
