Can i connect iphone?
If it is an 07, then no you cannot connect it and use the nav screen... that was in the 08 that they put the mygig in with the fancy touch screens, and ipod/iphone hook up.
Trust me I have searched this exact thing before. I'm sure you could upgrade the wiring in the 07 to acceapt the mygig setup, but as it stands now, NO you cannot hook up an iphone to the 07's stock nav screen.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
Actually, you CAN. However, it won't be bluetooth and it won't be "stock." You can buy a wiring harness from iSimple that simply plugs in the the stock harness and uses the VES input. Therefore, you plug your phone in (also has a 3.5 mm plug in addition to the iphone charger port style plug) and turn the setting to Mode 1 (or 2) rather than CD or SAT. That is, however, if yours did NOT come with the stock DVD system. I didn't have a VES option on my head unit until I installed the iSimple adapter.
FYI - the adapter works awesome (even charges the phone and I can control it from the steering wheel). Only bad part is it's not really "hands free," since I have to manually make the call (or use Siri), but it does play through the speakers
http://mofv.com/mygig/
ww4cash
Jan 4, 2012 08:47 PM
