Can i connect iphone?
Old Aug 17, 2012 | 08:33 PM
Cristina's Avatar
Default Can i connect iphone?
I want to buy a Aspen 2007 from one of my friend,i need to know that can i connect iphone with it's naviDvd?
Old Aug 17, 2012 | 09:09 PM
15951a\'s Avatar
Yes, but you might need to update the software for the mygig system. You can do it yourself for free.
Old Aug 18, 2012 | 07:03 AM
Cristina's Avatar
Default thanks
Could you please tell what is the procedure to do that?By the way thanks in advance.
Old Aug 31, 2012 | 12:45 PM
churnee's Avatar
If it is an 07, then no you cannot connect it and use the nav screen... that was in the 08 that they put the mygig in with the fancy touch screens, and ipod/iphone hook up.
Trust me I have searched this exact thing before. I'm sure you could upgrade the wiring in the 07 to acceapt the mygig setup, but as it stands now, NO you cannot hook up an iphone to the 07's stock nav screen.
Hope that helps.
Old Sep 8, 2012 | 04:53 AM
conversion02's Avatar
Hope that helps.
Actually, you CAN. However, it won't be bluetooth and it won't be "stock." You can buy a wiring harness from iSimple that simply plugs in the the stock harness and uses the VES input. Therefore, you plug your phone in (also has a 3.5 mm plug in addition to the iphone charger port style plug) and turn the setting to Mode 1 (or 2) rather than CD or SAT. That is, however, if yours did NOT come with the stock DVD system. I didn't have a VES option on my head unit until I installed the iSimple adapter.
FYI - the adapter works awesome (even charges the phone and I can control it from the steering wheel). Only bad part is it's not really "hands free," since I have to manually make the call (or use Siri), but it does play through the speakers
Old Sep 25, 2012 | 12:20 PM
Ryland's Avatar
I have an '08 Aspen and I can't find how to update the mygig system... Does anyone know how?
Old Sep 25, 2012 | 01:25 PM
ChryslerCares's Avatar
The following site has the latest Gracenotes updates and instructions on how customers can update the MyGIG system straight from Harman Becker:
http://mofv.com/mygig/
thedukesmom1
Oct 26, 2014 10:23 PM
bsparks
Sep 19, 2013 07:26 AM
ww4cash
Jan 4, 2012 08:47 PM
Oxnardboy
Jul 19, 2007 04:40 PM
Oxnardboy
Apr 9, 2007 02:55 PM
