Drivers Side Seat Bottom... leaning
My drivers side seat bottom is starting to lean towards the door from sliding in and out and it's becoming annoying while driving. Anyone else have this problem or know of an easy fix?
If I could get up in there, I could add foam to build it back up. I haven't gotten under there yet. Just figured I'd ask before getting into it.
That's a new one. Sounds like the seat cushion is collapsing/wearing unevenly. I'd order a new cushion and replace it if you're comfortable dealing with removing and reinstalling the leather cover. You have to move the seat up, disconnect two bolts and clamps underneath the seat, disconnect the wire harness, and remove the J-straps holding the cover and the cushion on.
When you put it all back together again, be sure to torque the bolts to 90 inch pounds (10 Nm).
Good luck!
Good luck!
Nick325is
Sep 4, 2007 08:15 PM
Jun 5, 2006 05:20 PM
