Extra Modifications for trailer towing
Old Aug 16, 2009 | 11:50 PM
bjushute's Avatar
Default Extra Modifications for trailer towing
Hello, I have a 2008 Aspen with a Hemi and the heavy duty towing package. We are purchasing a lite weight holiday trailer. It is 24 ft and will be about 5,500 to 6,000 lbs all loaded. I find the suspension in the Aspen a bit soft. Has anyone considered adding air bags or gas shocks to the rear suspension to firm things up for towing?
Thanks, B
Old Aug 17, 2009 | 03:24 PM
hardtop's Avatar
Make sure you using an equalizer hitch, and you won't have that much sag, and softness
Old Aug 18, 2009 | 07:53 AM
hemisfear's Avatar
I replaced the stock shocks over a year ago to firm up the ride and stop the rear from skating over bumps . My first choice was Blistein which I have used before , if you are worried about nose dive , rear end squat or less body roll Blistein's are a very good choice around $100 each . The Monroe Reflex is the one I picked which is the same as the Rancho RSX but with different packaging , by the way Monroe makes the RSX . I don't tow that much so general ride comfort is what I was aiming for .
Old Aug 19, 2009 | 10:03 PM
bjushute's Avatar
HI Thanks for the tip. I've found the skating a bit annoying as well. Did you replace anything on the front end?
Cheers, B
Old Apr 27, 2010 | 10:58 PM
Amazn1's Avatar
I tow the same weight trailer as you. I am going to get firestone airbags installed in the rear. I hope that will help with the saging since I already have an equalizer weight distribution hitch. I was also told that the bags will help with the rocking motion when towing over uneven pavement, we'll see.
Old Apr 28, 2010 | 08:55 AM
kkreit01's Avatar
Good tip. So, did the Reflex shocks eliminate the "rear skating"? Mine does this also.
AlaskaT&C
Jun 15, 2011 05:36 AM
Roni0518
Cirrus & Breeze
Apr 25, 2011 10:07 AM
ma210
Oct 1, 2010 09:56 PM
betrowbridge
Dec 17, 2007 09:09 PM
skjones007
Mar 24, 2006 07:43 PM
