Full size spare tire
I have the 20" my spare is an 18" hopefully the OD is the same otherwise will have a problem with the differential ratios, anyone know if they are the same OD, because on a AWD your aren't allowed to change tire sizes, and was wondering how long the spare could be used safely.
ORIGINAL: ssaspen08
Just checked my spare tire size. It's 245-70R-17 with a black rim and the tires on the chrome rims are 265-50R-20. Will the different tire sizes be a problem if I ever need the spare?
I don't think the ESP system will work unless the diameters are very close to each other.
After checking the tire calculator at 1010tire.com I guess we're OK. Both sizes are pretty darn close (to my surprise I guess the Chrysler engineers have this covered).
Section Width: - -
Tire 1 - 265/50R20 Section Width: 10.43 in 265 mm
Tire 2 - 245/70R17 Section Width: 9.64 in 245 mm
Rim Diameter: - -
Tire 1 - 265/50R20 Rim Diameter: 20 in 508 mm
Tire 2 - 245/70R17 Rim Diameter: 17 in 431.8 mm
Rim Width Range:
Tire 1 - 265/50R20 Rim Width Range: 7.5 - 9.5 in
Tire 2 - 245/70R17 Rim Width Range: 6.5 - 8 in
Overall Diameter: - -
Tire 1 - 265/50R20 Overall Diameter: 30.43 in 772.92 mm
Tire 2 - 245/70R17 Overall Diameter: 30.50 in 774.7 mm
Sidewall Height: - -
Tire 1 - 265/50R20 Sidewall Height: 5.21 in 132.33 mm
Tire 2 - 245/70R17 Sidewall Height: 6.75 in 171.45 mm
Radius: - -
Tire 1 - 265/50R20 Radius: 15.21 in 386.33 mm
Tire 2 - 245/70R17 Radius: 15.25 in 387.35 mm
Circumference: - -
Tire 1 - 265/50R20 Circumference: 95.59 in 2427.9 mm
Tire 2 - 245/70R17 Circumference: 95.81 in 2433.5 mm
Revs per Mile: -
Tire 1 - 265/50R20 Revs per Mile: 683.5
Tire 2 - 245/70R17 Revs per Mile: 681.9
Section Width: - -
Rim Diameter: - -
Rim Width Range:
Radius: - -
Circumference: - -
Revs per Mile: -
