Hello! 1st post... couple of questions
Old Feb 5, 2013 | 02:46 PM
Lassie's Avatar
Default Hello! 1st post... couple of questions
I have a 2008 base Aspen with 120k on it and am having some issues... so I was hoping someone would be able to point me in the right direction. My first problem is a check engine light that is telling me that I have a small evap leak. I just had the check valve replaced in the fuel filler neck and it did not seem to cure the problem. The second problem is an intermittent problem of the vehicle not wanting to start and displaying a "no fuse" message on the dash. I just bought a new battery and it seemed to fix the problem but it has come up again every once and a while. I swear I think it is a fuel delivery problem. Turns over great but just takes a few seconds before it starts. I have checked every fuse in the car at least four times and cannot find a blown fuse anywhere.....
Thanks for any help!
Jeff
Old Feb 7, 2013 | 09:07 AM
15951a\'s Avatar
Sometimes a new gas cap can fix the small evap leak issue. If not, could be evap lines/canister/solinoid.
The "no fuse" message can be triggered by a lot of things. If you already replaced the battery and checked fuses, it can be caused by door/liftgate switches not making a connection.
neex
Aug 28, 2013 01:52 PM
pittstategorilla97
Nov 11, 2008 03:13 PM
harko5
Oct 20, 2007 03:10 PM
davet
Dec 20, 2006 03:08 AM
raiderzx24
Sep 19, 2005 10:48 PM
