How do I remove metal rope and center holder from spare tire
Old Sep 3, 2016 | 07:23 PM
New but used Aspen's Avatar
Default How do I remove metal rope and center holder from spare tire
Can lower the spare but there is a holder in middle of tire. Looks like it should be knotted through the center hole. However, also looks like the wire rope will stop it from coming back up through the hole.
Old Sep 4, 2016 | 12:15 PM
calamity coyote's Avatar
Unless the cable/bracket has been modified, you are suppose to lower the tire via the wench cable until the tire is flat on the ground and has some slack in the cable. Then you lift one side of the tire to put more slack on the cable. Then you turn the bracket at an 45 degree angle to the tire to slide it through the center hole with the cable still attached to it. Basically, if the tire was laying flat on the horizontal axis, the bracket will need to be vertical to slide through. Hope that explains it for ya.
rmichels
Jul 28, 2015 04:38 AM
goggs
Nov 16, 2012 02:51 PM
Triple Black 88
May 7, 2012 01:02 AM
besterfe
Jan 16, 2012 10:53 PM
t_striker
Mar 3, 2010 07:31 AM
