Instrument cluster going nuts randomly.
Old Jun 14, 2020 | 05:23 PM
Frustrated Aspen owner's Avatar
Default Instrument cluster going nuts randomly.
Need some help..As you can see the gauges will randomly flicker. It doesn't turn off cruise control or the climate control..The raduo will turn off when the gauges do this. It may do this for 20 min non stop. It may do it twice and quit..I have changed the instrument cluster and checked all the fuses.. I am at a loss..Sorry if this has already had its own thread. I hope the amazing people on this fourm can help.. P.S. This is an 07 Aspen Limited.
Old Jun 29, 2020 | 10:26 AM
Big Joe's Avatar
Check the thread below
2007 Chrysler Aspen acts crazy when rains
this is usually caused by a plugged sunroof drain, causing water to run down the A pillar on drivers side.
Old Jul 7, 2020 | 01:49 PM
elusive416's Avatar
This happened to me when my ECU fried. Also wouldn't start. New computer, never happened since.
Old Jul 13, 2020 | 08:12 AM
45Frank's Avatar
Mine did that after I left the sunroof open and everything got wet.
On the lower left side kick panel I had to remove each relay and blew it out with air, let it sit a few hours and blew it out with dry nitrogen. Put all back together no problem since. While I had things apart I blew out the roof drains too.
agravitt
Jan 8, 2016 11:15 PM
dwstoick
Mar 16, 2013 12:13 AM
covey6
Nov 4, 2011 09:00 AM
Brian0514
Dec 7, 2010 10:34 AM
lc42481
Nov 1, 2008 12:18 PM
