New Aspen Owner - Road Noise?
Old Jun 28, 2014 | 05:49 PM
Ponderosa340's Avatar
Default New Aspen Owner - Road Noise?
Hi,
I just purchased a 2007 Aspen with 71000 miles. I picked it up in Denver and drove it over the mountains without a problem. Love that Hemi!
One thing I am concerned about is the road noise. I test drove an 09 and it was as quiet as could be but this one is noisier than my old caravan.
Does anyone know if the 07's were just noisier or could there be an issue.
It's even noisy just driving around town. Almost seems like a rear end whine.
Any info would be greatly appreciated.
Thanks,
Brad
Old Jul 9, 2014 | 09:23 AM
15951a\'s Avatar
If it's a rear end whine, you'll need to get that checked out. If it's wind noise, take a look at your doors from the outside when they're closed. One or more may need to be realigned.
Old Jul 9, 2014 | 10:53 AM
Thanks! I'm having the axle fluids changed out and I'll check the door alignment.
Come to think of it, the rear passenger door looks a hair high.
Thanks again for the tip!
Old Jul 22, 2014 | 01:25 AM
amschick's Avatar
Did you get the wind noise solved?
Old Jul 23, 2014 | 07:36 AM
Not yet. I'm taking it in for the fluids change this weekend. I also noticed the right rear rim is bent which may have somethingto do with it.
One thing at a time tillI figure it out I guess.
Old Oct 26, 2015 | 05:53 PM
Default Found it!
So after a year I got a new mechanic and he found out the bearings in the rear end were going out. He said its a pretty common problem with those rear ends. By buddy with an 09 Ram said he had his in to the dealership 3 times for the same issue. Hopefully my guy is better than the dealership.
Had the bearings replaced and the front end aligned and she is much quieter now. Once I get the new tires on she should be like a new car!
Old Oct 27, 2015 | 04:59 PM
calamity coyote's Avatar
Wow. Good to know. I was going to say possibly tires. I know the off road ones make more noise. Glad you found the problem.
Old Dec 9, 2015 | 06:27 PM
bjmaclean's Avatar
Some tire are wider than others and if they protrude out beyond the fender flares you will get noise.
BossLady
Mar 26, 2012 12:14 PM
shadetreemech
Apr 12, 2008 09:08 AM
lwkoss
Mar 3, 2008 06:10 PM
Chiketkd
Feb 6, 2006 12:02 AM
Apr 18, 2005 05:04 PM
