reverse camera not coming up on screen 2009 aspen hybrid
Old Sep 15, 2012 | 03:58 PM
docdrs's Avatar
Default reverse camera not coming up on screen 2009 aspen hybrid
My reverse cam is no longer working. I did have it in for service and the battery was drained dead and had to be put on a charger for a bit so the vehicle could be started. Can I disconnect the battery , would this do a reboot on the ecm?
Old Sep 17, 2012 | 01:52 PM
ChryslerCares's Avatar
When performing repairs that require battery cable removal, the feed fuse for the radio/dvd (30amp) must be removed prior to disconnecting or reconnecting the battery. Disconnecting and Reconnecting the battery can cause electrical spikes that may damage system. Removal of the fuse will prevent this from occurring.
Would suggest to first pulling the ignition-off draw fuse (IOD fuse) to see that will reset the system. The term ignition-off draw identifies a normal condition where power is being drained from the battery with the ignition switch in the Off position. The IOD fuse feeds the memory and sleep mode functions for some of the electronic modules in the vehicle as well as various other accessories that require battery current when the ignition switch is in the Off position. The only reason the IOD fuse is disconnected is to reduce the normal IOD of the vehicle electrical system during new vehicle transportation and pre-delivery storage to reduce battery depletion, while still allowing vehicle operation so that the vehicle can be loaded, unloaded and moved as needed.
The IOD fuse is disconnected from Integrated Power Module when the vehicle is shipped from the assembly plant. Dealer personnel must reconnect the IOD fuse when the vehicle is being prepared for delivery in order to restore full electrical system operation. Once the vehicle is prepared for delivery, the IOD function of this fuse becomes transparent and the fuse that has been assigned the IOD designation becomes another Fused B(+) circuit fuse.
The IOD fuse can be used by the vehicle owner as a convenient means of reducing battery depletion when a vehicle is to be stored for periods not to exceed about thirty days. However, it must be remembered that disconnecting the IOD fuse will not eliminate IOD, but only reduce this normal condition. If a vehicle will be stored for more than about thirty days, the battery negative cable should be disconnected to eliminate normal IOD; and, the battery should be tested and recharged at regular intervals during the vehicle storage period to prevent the battery from becoming discharged or damaged.
Chrysler Information
Jan 4, 2018 07:03 PM
jojo204
Feb 17, 2015 06:26 AM
Chrysler Forum Editor
Oct 6, 2014 05:08 PM
chris565
Jul 24, 2012 04:44 AM
chris565
Jul 16, 2012 11:53 AM
