Water Leak Passenger A post
Old Apr 16, 2016 | 12:05 PM
tmills's Avatar
Default Water Leak Passenger A post
I have an 08 aspen that I bought used. When I got the car there was a problem with the molding that covers the air bag on the A post. It had come off or been damaged and was being held in place by a drywall screw. I had that repaired before we took possession of the car.
Well its been 6 months and now we have a water leak that appears to be coming from the same area. The water comes in and shows itself coming out the bottom bolt hole on the A post molding and it drips down from under the dash in the same area ending up on the floor.
I started by cleaning out the weather striping above the door. There was a lot of dirt and leaves in that area and I thought maybe the lack of drainage may be allowing the water to get in. It kept leaking.
Next I took off the plastic piece that is on the car body A post next to the windshield. There is 4 screws that hold it on and a couple werent very secure so I put silicone around an area of the windshield and in the screw hold that I though may be letting the water in to no avail it is still leaking.
Any ideas on how to go about finding where the water is coming in?
I will try and add pics to make it easier to see what and where.
Old Apr 21, 2016 | 12:10 PM
cloutiersi's Avatar
Do you have a sunroof ?
Most cars nowadays have either 2 or 4 drain tube. Two of which follow the A pillars. Maybe the one on the side of your leak has a hole or something.
Just thinking out loud...
Simon
Old Jun 23, 2016 | 05:31 PM
04topless's Avatar
Drain tube on Sunroof....Must be cleaned.....$100 at the dealer....
Old Jul 6, 2016 | 11:40 AM
tmills's Avatar
I took care of my water problem by cleaning both of the drains and boy were they clogged.
mraskin
Apr 29, 2016 11:21 PM
David Robertson
May 29, 2012 02:44 PM
loungesurfer
Sep 29, 2011 11:57 AM
tracyk
Sep 20, 2011 12:36 PM
nirah
Oct 1, 2007 06:18 PM
