Chrysler Crossfire & Crossfire SRT-6 The base model offers a coupe, convertible, or roadster, but regardless of the model chosen this luxury sports car offers pure driving enjoyment and for those who want a few extra ponies under the hood the supercharged model offers the driver 330 hp
old repair post, that a new user needs help with
Old Apr 18, 2012 | 02:52 PM
Meanberg's Avatar
Default old repair post, that a new user needs help with
domcarlin07-08-2009 10:45 AM
2003 crossfire (25000miles) with engine noise?
Hi folks
Any ideas on the following problem? I have a low milage 2003 crossfire that has developed very bad engine noise. I can only describe it as a knocking noise which is much more noticable when the car is moving extremely slowly or stopped (eg at traffic lights). The noise doesnt seem to be affected by the engine being warm or cold. If anything it appears more noticable after driving for half an hour say, and then slowing and stopping (at junctions or lights).
Ive had the oil changed and a new oil filter inserted to no avail by a local non-specialist mechanic. He did mention a possible problem with one of the pistons being out of sync. but someone else has told me that that in this car that is impossible as all the pistons are linked together? Im totally ignorant of the workings of the car and am looking for a few ideas from anyone who is more knowledgable than me as to what the problem might be.
Any ideas would be very very helpful. Thanks in advance.
Mine is a 2006 with the same exact problem.
dcotter057907-11-2009 08:17 PMYes, the pistons are all linked together by the crankshaft. You mentioned that you changed the oil. Is this the first time you changed the oil in 25,000 miles? What is the oil change history of the car?
CHRYSLER TECH07-12-2009 09:51 PM"non-specialist mechanic" they scare me
domcarlin07-13-2009 05:48 PMThe car had a perfect service history when i bought it (at 20000 miles)...ive topped up the oil twice and had the oil changed on two occasions between then and now (once at its MOT and a few weeks back when the mechanic was having a look to see if he could identify the problem).
Just a bit more detail about the problem...when the car is in neutral gear and im stationary the noise is quite apparent. If i leave the car in neutral and rev the engine (even slightly) the noise dissapears almost instantly.
dcotter057907-13-2009 09:45 PMSounds like rod knock. If a bearing in the engine fails, you can get that kind of noise. Whatever it is, it's not going to get better by itself. Actually, it will only get worse. A "specialist" mechanic will probably want to listen to the noise using a mechanic's stethoscope, and may be able to pinpoint it much better than any guessing that could be done long distance over the internet. Depending on the diagnosis, it may be necessary to pull and rebuild the engine. I don't know if Chrysler extended a 7-year, 70,000 mile warranty to that car or whether it would be transferable to a second owner, but you should check to see because this is going to be an expensive repair if it's a failed engine bearing.
domcarlin07-14-2009 11:03 AMbeen doing a bit of internet searching on this rod knock (im praying it isnt that)...a few people have mentioned that the noise associated with rod knock gets worse or more noticable at 2.5-3k revs. Mines doesnt seem to do this...the more revs i apply the less i seem to notice the sound.
I went out and started the car cold this morning. No noise at all. After 4-5 minutes including a bit of engine revving in neutral to warm the engine the noise appearred (does this rule out piston slap???...i believe piston slap gets better as the engine warms?)...just a constant ticking/knocking/tapping. Ive also read that rod knock is more noticable from the bottom of the engine but without a stethescope it was impossible for me to tell where exactly it was coming from EXCEPT that it was definitely in the vicinity of the engine.
The pattern in neutral is this...vroooom (rev the engine and the noise is less noticable)...as the revs fall a second or two after taking my foot off the gas then the noise appears...knock,knock.knock...vroom (rev again and the noise lessens). I HATE to say it but from what ive read i think it is rod knock (the only thing that doesnt tie in with this diagnosis is that the knocking sound does NOT get worse as i approach 2.5-3k revs???)
As mentioned i think it is impossible to get an accurate definite diagnosis over the net. One more question though...ive phoned a Mercedes dealer (Mercedes engine i believe) in the area and asked if they could look at the problem for me...they said they dont have any Chrysler software? and couldnt do it.
Am i best going to a chrysler garage? rather than waste more more on "non-specialist" mechanics??? Basically what im asking is "Could most reputable mechanics diagnose this OR do i need a chrysler mechanic?"
Once again thanks for ANY reply
Dom
dcotter057907-15-2009 03:56 PMI don't think software has anything to do with it. This is a mechanical problem, not a computer-related problem. Frankly, I wouldn't go to a dealership with a problem like this unless it was under warranty. Very few dealership mechanics have ever rebuilt an engine. The usual approach in a dealership dealing with a warranty problem is "R & R", remove and replace. It's more cost effective for them to replace the engine than re-build it. Ask around town for somebody who rebuilds engines, especially German engines.
If you want to invest in a mechanic's stethoscope, hunt one down on the web. You should be able to find one for less than ten bucks.
Good luck to you on this.
Meanberg04-18-2012 03:07 PMI have this exact same issue!
Did you ever find out what it was?
Meanberg04-18-2012 03:13 PM...or does anyone else have any more insight?
Old Apr 18, 2012 | 07:47 PM
xfire04's Avatar
Welcome to the forum Meanberg
i cant make any sense out of your post go to www.crossfireforum.org an do a search you might find something
Old Apr 19, 2012 | 08:08 AM
Meanberg's Avatar
thanks for the re-direct, I simply reposted an old thread because I am having the exact same problem as the other user: Knocking only at idle, usually after the car is warm. Any ideas on what it is? Previous thread seems to suggest it's rod knock... would high milage oil help with this? I have 80k
Old Apr 19, 2012 | 09:26 AM
xfire04's Avatar
doesn't sound like rod knock to me rod would knock when you raced up the motor also
Old Apr 20, 2012 | 08:36 AM
Meanberg's Avatar
yeah that's what I would have thought too... only car I ever really worked on was my DSM eagle talon turbo awd. it's hard for me to think of what it could be, because it only happens at idle. maybe something the A/C system? thanks for taking the time
Old Apr 20, 2012 | 11:07 AM
xfire04's Avatar
best thing is to find a mechanic that works on mercedes cars
you do know crossfires are mostly mercedes he would be familiar with the engine an let him listen to the engine
Old Sep 19, 2012 | 05:26 AM
daviddav1121@gmail.com's Avatar
Western Union Transfer MTCN for Sale
WESTERN UNION TRANSFER
Most Respectable customer, i am sharp minded Hacker, having very beautiful ideas to transfer money to you by western union. i am working since last 5 years in this field. i know many techniques to transfer funds from western union website to you
1. TRANSFER MONEY BY USING WESTERN UNION BUG
There is software, use for hack the date from western union website, we use this software to transfer any amount to any country as per your requirement. Now it is very easy to transfer money from western union website to you, if you are interested we can transfer funds to you. contact us Rootasing@yahoo.com
2. TRANSFER WESTERN UNION BY USING CREDIT CARDS.
We are hacker team, we have hacked a lot of credit cards from different websites and banks. you can not imagine that how much credit card date we have. To transfer money from western union website to you. we upload funds into western union account from credit cards and then give to you. Credit cards is use to fund the western union account and then can transfer to you. contact us Rootasing@yahoo.com
3. WESTERN UNION MASTER CARDS
Western union offer Master cards to get transferred money any part of the world. We also sell Western union MasterCard with high balance. This is plastic card and can be used for online shopping and ATM withdraw. If you are interested to buy Western union master Card with Balance of more than 5000$. We can ship this to your postal address
if you are interested to get easy money by western union, you can contact us Rootasing@yahoo.com
PRICE FOR WESTERN UNION TRANSFER
Pay 500$ = Get 8000$ western union transfer MTCN
Pay 400$ = Get 4000$ western union transfer MTCN
Pay 200$ = Get 1000$ western union transfer MTCN
Western union Master card with Balance is more than 5000$ = Price is 300$
Western union Crack Software for sale with activation key = Price is 300$
BUSINESS RULES
i only accept payment by Liberty Reserve & western union
You will get MTCN number with in 30 minutes after payment
I do not deal small order or test order. it is just waste of time for me.
You will get your order completed maximum + maximum 24 hours
i will give you mtcn number and sender name + country
i do not offer % partnership for new client.
if you are facing problem to collect money, (with in 2 hours)
No test Free, otherwise every one ask for test
Please do not spam me, i hate spamming
i do not want talk a lot, just speak to the point
if you do not want to buy any thing from me, please do not contact me
CONTACT :
Rootasing@yahoo.com
western union transfer, bank login, bank transfer, paypal login, fullz, credit cards all available WU transfer, PayPal, CC, Cvv
Old Feb 27, 2013 | 08:15 AM
ahmad66265's Avatar
Banned
doesn't audio like rod affect to me rod would affect when you competed up the engine also
__________________
04 Crossfire
K&N Filters
Magnaflow Exhaust
Dark Colored Window
Roof spoiler
Billet Grille
new battery
new tires
( FOR SALE )
highlands
Jul 19, 2013 01:17 PM
Necro1015
Feb 28, 2013 04:11 PM
haarp425
Dec 11, 2010 07:01 PM
mreedtec
Sep 3, 2007 11:58 PM
