04 Pacific - low beams not working
Old Dec 13, 2009 | 09:23 AM
scott04's Avatar
Default 04 Pacific - low beams not working
2004 Pacifica - Both of my low beams stopped working at the same time the other day. They didn't turn off on me, just didn't come on the next time I turned the headlights on.
Two days later, the right low beam light worked but the very next day it stopped working again. From that, I guessing the problem isn't with the low beam bulbs or the fuses.
Any advice would be appreciated.
Old Dec 13, 2009 | 01:44 PM
pac10's Avatar
I would check the connecting plugs to the headlight housing, build-ups in the contacts can sometimes stop current flow. Use a volt-meter and trace back from there if you don't have a reading.
Old Dec 14, 2009 | 02:26 PM
Check the bulbs first. May sound odd but it could still be the bulbs. A filament can break but then re-connect if jarred and work again for a short time.
Old Dec 16, 2009 | 08:41 PM
scott04's Avatar
Problem solved: Believe it or not the problem was with the headlight bulbs. In the right headlight assembly, I switched the low beam bulb and the high beam and presto...they both worked. So I switch them back and the low beam bulb has been working ever since. However, the left low beam bulb was indeed blown. I replaced it tonight and it works. I not sure why the right bulb went out at the exact same time as the left and then the right came back on for a day and then out again. Seems weird but at least they're working again.....for now. Thanks for the replies for advice.
wig6516
Feb 6, 2016 08:10 PM
Big_Rob
Nov 25, 2012 12:17 PM
johnseattle
Jun 20, 2008 07:47 PM
johnseattle
Jun 20, 2008 02:11 PM
cgaeth
Jul 4, 2007 11:08 AM
