04 pacifica low beam headlight not working.
Old Jun 21, 2020 | 01:12 AM
oldtwentyone's Avatar
Default 04 pacifica low beam headlight not working.
Hi everyone, My drivers side low beam headlight stopped working. All my other lights still work fine. My 04 came with DS2 HID lights. they have a blue tint to them. The first thing I did was replace the bulb with no results. Next I checked the power and ground with a test light at the headlight plug. I had to look at a wiring diagram to get the wire colors. The left low beam power wire is (white/dark blue) The ground is (black/light green) Both wires are working. How ever I did find a ground wire that is (green/white strip) that's not working. I thought that must be the problem. So I looked up the ground on the diagram. It is location 103. Which is on the drivers side frame below the battery. their are 3 post close together down there. I think 103 is the post farthest forward towards the bumper. None of them looked that bad, moderate corrosion. I removed and cleaned the post and connector. Still grn/white wire no ground. Next I'll clean and tighten the other 2 ground posts down there to see if I can get the ground working. I don't Know what else to do if that doesn't work. Could the headlight can itself go bad?
bm94bd
Jan 21, 2021 09:25 AM
realrobd
Mar 9, 2019 05:33 PM
vgarfield
Dec 18, 2013 11:19 AM
kmc90
Nov 24, 2013 09:59 PM
scott04
Dec 16, 2009 08:41 PM
