04 Pacifica Oilpan
Old May 5, 2009 | 03:58 PM
servo's Avatar
Default 04 Pacifica Oilpan
Does anyone know if there is a lot involved in changing the oilpan? My local Chrysler dealer stripped the drain bolt.
Thank You.
Old May 5, 2009 | 05:18 PM
redhill's Avatar
Here are some options:
1) New Oilpan= lotsa bolts, gasket removal, gasket replacement. $ parts+labor
2) oversized self-tapping plug is a tapered plug, but are prone to leaking if the original hole was badly stripped. Very easy to do, just make sure you do not over-torque!
3) helicoil works well if you re-tap it straight so the plug seats properly. Maybe practice tapping holes before you try this for the first time.
4) re-tap the hole and use a bigger plug. Also easy to do with a bit of practice
Old May 8, 2009 | 11:32 AM
servo's Avatar
Thank You redhill. My mechanic is going to retap.
Old May 18, 2009 | 08:02 AM
PacificaBus's Avatar
If the dealer stripped it make them change it for free! After all they're the cause of the problem.
