04 Pacifica Trans/Electrical
Old Sep 28, 2009 | 12:34 PM
jan02rj's Avatar
Question 04 Pacifica Trans/Electrical
My car will not shift out of first gear and I get ZERO speed indication, Tach works fine. I also do not get gear indication on the instrument panel. I was wondering if this was a transmission speed senor problem or something else. Do not know if this related but I replaced the altenator yesterday. Figured the speed and gear problem on my test drive, also auto stick will not work either.
jan02rj
Old Sep 28, 2009 | 08:45 PM
Output speed sensor problem? That's a relatively cheap and easy fix if it's the problem. Take it to a dealership and they will hook up their DRB III scan tool to the car and find out quickly if it's an electrical problem.
Old Sep 29, 2009 | 06:49 AM
jan02rj's Avatar
Question Tried
I changed the input and output speed sensors, checked all fuses still no joy. Does anyone think it could be a Transmission control module?
jan02rj
Old Sep 29, 2009 | 11:42 PM
mrfixit454's Avatar
Have you tried removing the neg. batt cable for a few minutes and then see if it works after you connect it back up? If you have, see post #2. Sorry, don't know what esle to do without trying to read codes.
Old Sep 30, 2009 | 06:50 AM
jan02rj's Avatar
Unhappy Battery
Yes I removed the negative cable and even removed the entire battery for over 24 hours. I think I will have to bite the bullet and go to the dealer and have it read out and maybe fixed there.
jan02rj
Old Sep 30, 2009 | 12:01 PM
u just made it harder by undoing the battery any and all codes were erased once u undid the battery.
mkz1
Sep 2, 2013 02:30 PM
struculeus
Sep 26, 2012 05:22 PM
parlayjay
Apr 18, 2010 03:28 AM
Pacifica3.82007
Apr 22, 2009 10:39 AM
X-Vehicle FTE
Apr 10, 2009 12:25 PM
