05 Pacifica turns over but doesn't start
I have a 2005 Chrysler Pacifica with 163,916 miles on it. A couple days ago the timing belt tentioner exploded causing it to lock up. It shredded the timing belt but didn't break it. I changed the water pump, Timing belt, and tensioner.... Car was running fine before this issue occurred. after replacing the parts and reassembling the cover the car now the engine turns over but doesn't start. I tore the motor down to the head and compression tested the cylinders. All 6 held compression. Valves were fine. I replaced gaskets and replaced crankshaft position sensor and camshaft position sensor. Engine still turns over but wont start. I then checked for spark on coil. I currently do not have any spark..... please help!
Originally Posted by bluesuby9186
(Post 70979)
