06 Pacifica ABS light
I have a 06 pacifica and the ABS light is comming on. Every so often the brakes chatter and catch. I took it in and they said I needed a new left rear wheel bearing for $500. Does this sound right? Thanks in advance, Joyce
nope u need wheel speed sensors not a wheel bearing and I would replace all of the sensors they have a bad habit of failing one after another the dealer has a TSB on this issue don't take it back to the people that told U that U need a wheel bearing.
Is the sensor connected to the bearing or is this something you can do in your garage? Everyone keeps telling me that the sensors are built into the bearing and both will need to be replaced. Is this true?
not true the chrysler sensors are the sensors only U haft to take loose the hubs not replace them.
(Post 25538)
2005 - 2006
At last, something on my vehicle not covered by a tsb...
if anything U want to have a tsb with that U know what the issue us and what it will take to fix it.
I had to have this replaced on right and left side of my 05' pacifica. Luckily i purchased extended warranty. :)
(Post 26186)
