06 pacifica slow response problem
I have a 06 pacifica touring AWD and I notice when the engine is not warm when I push the gas pedal the car do not response for a couples of seconds. I when to the dealer and the told me was wrong spark plugs and a bad EGR valve and wrong spark plugs, and because the bad EGR valve the fuel injector can be clog, they recommend fuel injectors service. I changed EGR valve and spark plugs and do the fuel injector service. The problem is still there. Does anybody have any idea about this???? Thanks!
Sounds more like a TPS (throttle position sensor) issue. I had a similar problem on a Dodge Daytona and Pontiac Sunbird. Replacing the TPS solved it. Since the computer didn't get the correct signal about how far the throttle was pressed timing was adjusted accordingly.
shirlock1
Nov 29, 2012 03:25 PM
bikerbeng
Oct 17, 2009 08:46 AM
hombreasiano
Feb 19, 2009 07:33 PM
redriderbob
Dec 6, 2004 02:09 PM
