07 Pacifica Navigation System Issue
Old Jul 16, 2011 | 07:36 PM
golfmarshal's Avatar
Default 07 Pacifica Navigation System Issue
All,
The navigation system for my Pacifica is saying "error reading disc" and continues "Loading..." for a couple minutes then turns off. My wife had pressed and held, she thinks, the NAV button and it reset the system and then was working for a day or two, but then went back to this same problem. Is this a problem with the NAV DVD in the back of the car? Does anyone have any suggestions? Thank you much!
Old Jul 18, 2011 | 07:15 PM
Default Navigation Issue
Does anyone have any suggestions for me on this? 62 views to date and no ideas? Please help...I am on standby. Thank you all!
Old Jul 22, 2011 | 05:24 PM
shaka38's Avatar
It sounds like the disc is defective. Have you attempted to clean the disc? Have you tried to play a dvd in it to see if it will load? I'm not certain if it is only for the nav disc or if it'll play movies. See what happens with the disc in your entertainment center to see if it loads or gives the same symptoms...? Just some thoughts and a response, not just a view.
Good Luck!
Old Jul 23, 2011 | 01:53 PM
Default Nav Issue
Thank you for the reply. I have tried 2 different model # nav discs with and experienced the same issue - model AE and model AH. Could the DVD player in the back end of the vehicle where the nav disc loads be the issue? Thoughts anyone?
Old Jul 24, 2011 | 11:57 AM
shaka38's Avatar
that would be my guess golfmarshal.
Roush08
Oct 1, 2012 09:30 PM
bobbyap
Jul 21, 2010 09:34 AM
gatzpup
May 13, 2010 01:01 PM
Racinfan83
Dec 27, 2005 04:42 PM
jandmp
Apr 14, 2005 12:56 AM
