2004 water pump / cylinder block drain(s)
Old Jul 12, 2016 | 07:14 PM
Blue flames's Avatar
Question 2004 water pump / cylinder block drain(s)
So, I'm in the middle of R & R of the radiator, water pump, timing belt & thermostat on a 2004 Pacifica with the 3.5 liter engine. The manual states to "Remove the cylinder block drain plug(s)" however there are no directions or figures to tell me where it / they are located. I'm not seeing anything that is obviously a plug in the block for the draining of coolant. Can any of the experienced (or not) Chrysler folks giver me some direction here?
Old Jul 12, 2016 | 09:05 PM
Not really necessary. You remove the drain plug to drain the cooling system, but when you disconnect the radiator hose you're going to drain the system anyway. It's a little messier but it'll do.
Old Jul 24, 2016 | 04:42 PM
So, completed the water pump, timing belt, tensioner & pulley, radiator, thermostat. Have leaks. Pulled front timing cover & appears to be from a few places through rear timing cover into cavity of timing belt & water pump. Manual says there are O rings that seal the water pump passages to the block. So to get to those, rear timing cover has to come off. I'm a little intimidated with that step.
From reading elsewhere on this forum, I'm pretty sure I don't have to remove valve covers & rocker assys. but do I need to do the following as pasted from the manual?
(4) Install a dial indicator in number 1 cylinder to check TDC of the piston. Rotate the crankshaft until the piston is at exactly TDC.
(5) Remove camshaft retainer/thrust plate from rear of right cylinder head (Fig. 152).
I am at TDC on the crank & camshafts.
Then it looks like I need to remove the alternator & power steering reservoir, but the manual doesn't say its necessary.
Any tips at this point.
Old Jul 24, 2016 | 07:51 PM
FIREM's Avatar
Block drain plugs are high on the block, just under the exhaust manifolds. No real need to remove as when the pump is pulled, block will drain.
No need to pull the covers/dial indicate etc if only replacing pump and belt.
Seals behind the water pump do require removal of the right cam sprocket, then the right rear timing housing. Special timing tool needed to index cam & sprocket.
Old Jul 24, 2016 | 09:45 PM
you will need to remove the V covers and Loosen up the cam bolts remove the back cam plates push the cam towards the driver side to get the cam bolt and gear to clear that tight area. This will need to be done to remove the timing cover that has the o rings on teh back of it.
Old Jul 25, 2016 | 12:07 AM
So Kevin, I'm guessing you're talking about the cam shaft thrust plates? Manual says to remove ONE on the right rear (Driver side) of cylinder head. Haven't looked real close yet but I'm guessing BOTH need to come off?
This manual could have been written a bit better.
So to get the rear timing cover off, I'm seeing that (from already completing the water pump & timing belt & putting it all back together) that both cam sprockets, the crank sprocket and the power steering reservoir all need to be removed. Is that correct? Is there anything else to come off?
I remove the thrust plates so the cams can be pushed partially out the drivers side (rear of engine) so I can get the bolts out/off that hold the sprockets to the cams?
I think if this car were a horse, I'd take it out and shoot it.
Thanks for the info to this point.
Greg
Old Jul 25, 2016 | 09:21 PM
Crank sprocket no The timing cover only goes down about 6 inches to teh crank so it will not need to come off. Yes the thrust plates will need to come off to back teh cams out far enough to pull the bolt out all the way. I just installed some 3.5 heads today on a Journey.
RacingJunk
Sep 2, 2013 05:48 PM
Andrew Sheridan
Jul 10, 2013 09:43 PM
Thusnelda
May 18, 2013 09:53 PM
dmbeale
15
Nov 24, 2010 06:26 PM
captain catfish
Oct 2, 2010 04:32 PM
