2005 Pacifica 3.5L battery drain
Old Jul 14, 2013 | 10:24 AM
ronney99's Avatar
Default 2005 Pacifica 3.5L battery drain
My battery drains over night. My ohm meter says there is a 2.56 amp drain.
I pulled out fuses 46, 47, 48 and 50. Now it has 0.0 drain. These fuse go to the panel lights, door stero, Cluster, HVAc, clock ect.
Question: How would you suggest I track down the battery drain problem from here?
Old Jul 14, 2013 | 10:35 AM
get a wire diagram and go fuse by fuse see whats on each fuse and if there are hard items like switches or modules unplug one by one until the drain is gone then u have found it .
Old Jul 14, 2013 | 10:46 AM
ronney99's Avatar
Thank you Kevin.
Should I purchase a wire diagram from Mitchells?
Old Jul 14, 2013 | 10:06 PM
there all the same
smturnbow
Mar 12, 2014 11:21 AM
mrbit27@gmail.com
Jul 29, 2011 09:21 PM
Hawwk11
Jun 20, 2010 04:35 PM
Dave Rogers
Mar 1, 2009 08:32 AM
quattj
Feb 2, 2007 10:30 AM
