2005 Pacifica Touring AWD Klunking noise up front
Hi, all new here!
I have a 2005 AWD Pacifica with some trouble RESOLVED 1_ A Sound in the right front Suspention area. sounded like PLOK on bump and hole. ++Was the sway bar bushing! RESOLVED 2_ The engine was moving a lot when going on reverse or forward. ++ Was the Engine ANCHOR some kind of mount under the airbox STILL SEARCHING 3_ Now i have an other klunking noise when i give it some gaz from death stop. Fell like the suspention is stretching more than it should be! Can hear a clunk in the front and can be feeled in the car! I dont have any clue of what it could be.. any feedback welcome!!! |
I have a 04 I checked all the bushings and such but when I break its clanking under my pedals and thuds the floor. Same issue?
Originally Posted by mythy
(Post 72588)
You, it could be brake or front lower control arm problem |
RESOLVED 1_ A Sound in the right front Suspention area. sounded like PLOK on bump and hole. ++Was the sway bar bushing! RESOLVED 2_ The engine was moving a lot when going on reverse or forward. ++ Was the Engine ANCHOR some kind of mount under the airbox STILL SEARCHING 3_ Now i have an other klunking noise when i give it some gaz from death stop. Fell like the suspention is stretching more than it should be! Can hear a clunk in the front and can be feeled in the car! ++ Find out the the front engine mount was badly beated!! Changed it and after a 4 wheels alignment the truck feel pretty damn good. No more sound , vibration and clanking noise!! |
I have a 2007 with 75k on it. Have the same thing under accretion and braking. Under the right front.And can not find it
Originally Posted by Kevin Matney
(Post 73272)
It may be the engine mount Had to change mine. (tough job) it is under the engine in the front. Plus you can check the top mount situated under the Air box. Let me know |
(Post 73272)
Also heard about several cases with loose bolts in sub frame making noise. |
